Hey guys.
Hey RB30-POWER, where did you get the instructions for the resetting of the idle on the RB25DET? I only ask cause it was my DIY posted up on here to invloving my idle reset from when i cleaned my AAC valve.
I can't remember 100%, but i'm pretty sure I got my method from the nissan engine service manual.
I might have got it around the wrong way like you've posted and its the TPS sensor that needs to be removed while adjusting the idle through the idle adjustment screw, and not the AAC valve as is the method for the RB20det.
Either way, it seems to work i spose, as it is the AAC assembly that allows more air in for idle if it thinks the car needs it, and by disconnecting this plug while adjusting the base setting then re-attaching the connection and looking for any differences in idle speed before fine tuning if need be (though i still haven't heard of any skylines requiring this step).
The best reason I can think of for disconnecting the TPS from the RB25 while adjusting the idle screw, is so that the value coming from the TPS is absolutely nothing, so even if the car thinks it has to compensate for a TPS setting or that the Throttle is even partly open, it won't affect the setting of the idle.
Or I may be completely wrong.
Edited by insu
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
