I cannot read dyno charts so im not too sure where i would be looking
Engine is a rb30det. 3", front mount, power fc and the turbo will be a kkr 480
can anyone maybe plot on the rb25 with kkr 480 graph where it should be with my setup?
or when i should start boosting and reach max boost?
just estimations...
thanks
Very hard to say as there isnt a lot of information around.
If you have a look in the KKR thread that i've seen you post in.
You will see that they are a little less responsive than similar sized/priced turbo setups.
There are a few graphs in that thread now, bearing in mind they are 2.5ltr motors and not the same as yours.
Obviously it would be more responsive on a 3ltr as opposed to the 2.5ltr, without a doubt.
How much however is hard to say
Maybe 500rpm... maybe more.
It depends on cam choice, timing and a lot of other variables like Comp Ratio etc.
I would have a stab, and a rough stab, that the KKR480 would come on around the same as a GT30 on a 2.5ltr based on the limited information that is avaliable.
There are loads of GT30/RB25 graphs in the sticky thread in this section that will give you a better idea
Are you using a stock RB25 head? Or do you plan on having cams etc?
It will definately be earlier, how much is hard to say.
It might not be traction friendly though.
in the other thread teejay quite rightly said it seems to be a light-switch style power delivery.
It would be more liner on the bigger motor, again, hard to say how much.
Is it a build bottom end?
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
