Ok its crunch time people. After enjoying this little car for about 3 years I now need to sell due to an up and coming extended holiday :ermm: in Europe
Genuine reason for sale - No swaps
1989 model first complied in 1996
- RB20DET with 5-speed & 4.3:1 diff
- R34 GTT turbo fitted running around 0.9bar (bleed valve)
- Chipped ECU by Toshi
- R33 GTR fuel pump
- High flow panel filter & Cat
- 3in turbo back exhaust
- R32 GTR alternator
- Timing belt was replaced about 25000km/2.5 years ago
**Fresh oil, filters, plugs & coolant added on the weekend (21/05/06)**
External mods:
- 17 x 8 and 17 x 9 SSR DeColte 3 piece wheels. Very lightweight
- Marangoni 235/40ZR17 and Yokohama DNA-GP 255/40ZR17 respectively
- R34 GTT wing
- 91-93 headlights
Inside
- JVC KD-LH2000 MP3 head unit (4 x 50w, 3 sets of RCA outs, coloured dotmatrix display)
- Pioneer 4in 2-ways in front & Pioneer 6.5in 3-ways in rear
- cabling for amp fitted
- option to buy 10in sub & 4 x 50w RMS amp as well (not fitted)
- Fully sick RAZO gear knob
Price drop to $11500ono with 12 months rego - PM me serious offers :D
http://transelite.net/SAU%20cruise%20n%20B...es/PICT0303.jpg
http://transelite.net/SAU%20cruise%20n%20B...es/PICT0301.jpg
Edited by cul202
  • 5 weeks later...
Not sure but best guess by my tuner was around 170rwkw. If you hit it at 60km/h in second it will start spinning/sliding at around 70km/h - with 255's on the rear
Edited by cul202
If you guys are serious about the car please organise with me to check it out :)
Ben, hopefully see you on Saturday!
Edited by cul202
Do you have anymore pics, can you please send to [email protected], mainly interested in some pics of engine bay, interior front and back etc!! Is all the suspension stock?
hey mate, what condition is the interior in? and can you organise a picture of the engine bay for this post?
do the rims sit flush with the guards? good offset??
i'm interested and am going to think about this car during the week, will come have a look on the weekend if i'm still keen. just looks a bit like a 4x4 in the pics, so have to use my imagination to see it lower.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
