hey guys, well i was given a turbosmart type III B.O.V. a while back off a mate who has taken it off his car, and he said to try it on my car to see if it worked good. anyway i didnt have the adapter for it , so i just never fitted it, but on the weekend my other mate gave me one off his old skyline that he had made up, so i fitted it up and took it for a spin, everything seems ok, except for 1 thing, on the stock indash boost gauge, where its says +7 / -7. The needle seems to be sitting just above the -7 on idle, now from what i can remember before i changed it, when it was on idle with the stock B.O.V, it sat right on the -7 at idle, why would this change???? any help on this matter, and what does it mean???
Edited by 85URK
https://www.sau.com.au/forums/topic/115901-vacuum-question/
yeah, might have a little leak somewhere. il have a look when i get a chance. if it does have a vacuum leak, does this mean it will be running less boost then im guessing.
there is a difference between vaccume leak and boost leak =)
try tighten the spring on the BOV a bit more to make sure that it is not leaking.
https://www.sau.com.au/forums/topic/115901-vacuum-question/#findComment-2133283
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
