How does the aftermarket steering wheel affect it? My Hicas is disable n removed, but ive also got an aftermarket steering wheel...my hicas light is on all the time..but recently it went off once or twice..which is weird when my hicas is totally removed...
One of the sensors for the hicas is to do with the steering wheel J-Boy, some aftermarket steering wheel mounting kits dont have the hicas connection. But i dont think it would matter if youve had the hicas removed.
have a search and find one of the pages about running one of the diagnostics. i think theres a guide on one of the last pages,
Can be any number of things.. But at least you dont lose power steering when your fuel tank is full, like me :O
Edit: Found one
Maybe some one should sticky some of the hicas stuff.
http://www.skylinesaustralia.com/forums/in...=77405&hl=hicas Is the topic that the link below is given in.
http://gtr.ferni.net/misc/skylinebook.pdf#...0specifications
Good luck getting the right left right left, diagnostic mode activation going, i couldnt hehe
Edited by 32thrasher
  • 4 months later...
Haha that looks crazy! Wonder if they didn't just make it up! lol - Ill give it a go on the weekend maybe...
Ive got an aftermarket steering wheel so I think thats probably my problem. :S
(Getting a safety on wednesday hopefully :) )
hey everyone. i need advice and ideas to point me in the right direction. the HICAS light on my dash stays on when i start driving, but randomly goes off 5 to 10 minutes later. any ideas or opinions will be much appreciated. thanks
How'd you go? Maybe checkout: http://www.skylinesaustralia.com/forums/in...howtopic=134731
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
