Hey guys,
Been reading on this forum for quite some time now and now finally deciding do to some purchasing of an r33.
what i was wondering is what peoples opinions are of an r33 gtst coupe(most likely series 2) being used as a daily driver. I have wanted one for quite some time now but because of age and insurance always decided against it. I am planning on using my line to take me to work and back everyday, which is a 40km drive(usually 1 hr), so 80km a day on weekdays.
What I am basically asking -is this a bad idea in your opinion? ;) What would be the pros and cons of this?
Cheers guys. :D
https://www.sau.com.au/forums/topic/116231-little-adviceopinions/
Umm I wouldn't see a problem in using it as a daily driver... Just about everyone on here does.
Pros on it would be you get to cruise for along time everyday in a Skyline :D
I guess ull be clocking up some k's on it quick.. but hey cars are ment to be driven!
With the fuel prices its gonna cost abit each week.
At 80K's a day you'll go through a full tank of premium per week so its up to you if you could afford it, assuming you get around 430K's out of a tank - ~$70 nowadays
For me, the highlight of the day is the drive to and from work so its worth it hehe
Good points guys.
Petrol will be no problem, plus I have plans to get my hands on a power fc and some kind of ebc.
Should have mentioned that one of the things that has me worried is reliability. At the moment I am driving a 92 Ford Falcon which is a work horse but a real bore to drive.
Mods will be kept fairly simple as I'm not searching any numbers(will c if I can keep this mindset once i've purchased the car :) ). plans are power fc, ebc, fmic, tbe, air filter and other suspension and brake mods.
I dont plan on keeping the ford. So am I gonna be spending most of time in hire cars while my car is in the workshop? :rofl: or can someone here speak on experience and say I should be ok?
Maybe a gtr would be a different story?? :ermm:
Depends if you buy a lemon - get a prospective buy checked out thoroughly (compression test!).
The RB25DET is a very reliable engine and can handle mods. Just don't expect 2JZ internals when you strap on a turbo and run hi boost.
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
