Put my Series 1 RSFOUR on the Dyno last night to see if it made factory power and look at the A/F's. It made 180rwhp (had front driveshaft disconnected for RWD dyno'ing) at about 6500rpm on about 6-7psi (factory solenoid high mode). So if you figure on 240hp @flywheel, and maybe 25% losses then 180hp is about right.
But it was superduper rich throughout which I kinda see as a problem! At idle it achieved 13.5-14.5:1, so made me think the o2 sensor was working in closed loop mode, but at cruise (about 10in. Vac - 2000rpm - 4hp) it went straight to between 11.1 - 11.4 :1, stupidly rich. And on a full power run it goes off the meter at the top end, running around 10:1 before meter says 'too rich' and stops measuring.
I discovered the factory bov was leaking when we pressurised the intake path with an air compressor to check for leaks (had to disconnect and block the bov recirc line to check for bov leakage). So tried another std nissan bov they had lying around, it too leaked (both leaked from 2-6psi). Wondered if other ppl's might be? I squashed mine up in the vice to increase spring tension (butcher I know but gonna replace it), but still leaked. But it's full recirc after afm, so wouldn't be causing richness.
Sooo I'm thinking i'm on a hunt for faulty components causing the richness before I just tune it out with a piggyback. If something's wrong best I fix it instead of just tuning away.
But I'm wondering if other guys with std Stagea's have seen similiar A/f's on the dyno???
https://www.sau.com.au/forums/topic/116446-super-rich-stagea/
Stock NIssan ECU's = SUPERMEGAHAPPYRICH fuel mixtures, my stock R33 ran as low as 7.5:1 running stock ECU, I would assume that the stock Stagea ecu would be about the same..?
All the RB25DET stock BOV's leak, if you do some searching you'll find out all kind of stuff about the stocker BOV.
I have a feeling that the Stagea ecu is slightly different, in the outer case at least), as in you cant read error codes on the ecu on a stagea but can on an R33 (true?).
I suggest getting a SAFC and tune that beast! 12:1 all the way.
Sweet I'm pleased to hear my car probably isn't broken and slammin' rich is the norm. You'd have to ask why though.. like what was running through the ecu engineer's mind? I know altitude - temp - etc but shit.
I'm probably planning on Greddy e-manage 2, supposedly they're the way. Dyno guy is tuning on one a car soon so he'll say how it goes. Bout 1k to buy, and has usb connection, designed for tuning with laptop which i figure is handy (if ya got one).
Tangles, is the SITC a little blue screen version of the ITC? I never knew they existed!
SITC had 5 dials that you can alter the Ignition Timing on....... no screens, although they give a nice glow when the powers on.
Apexi Super-ITC or Super Ignition Timing Converter
see SK's thread, pics and all: http://www.skylinesaustralia.com/forums/in...c=80642&hl=sitc
Edited by Tangles
wicked, im about to pick one up to compliment my SAFCII. It was sold as a ITC not a SITC, so I thought there might have been a difference.
Thanks mate.
No probs!!
I gained 20kw when I added the SITC and a fuel pump (direct wired) & Z32 afm, tuned at 12psi up from 10psi. Best of luck with it.
fyi: I got a Brand New SITC off ebay for $200US LOL, never ever seen another brand new one for sale.
As I said earlier I wanted to get the S1 tuned as I thought it was running a bit rich. 15+/100kms, plus the exhaust is very sooty.
All the technical terminology in this topic puts me off a bit.
What is a simple economical method of getting a tune up?
Take it to a trusted tuner, give him lots of $$ and get your vehicle back with a couple of extra piggyback ecu's and a decent tune. Easy :/
Or buy what Tangles bought, SAFC (Super Air Flow Converter I think..?) or a SAFCII (Same but a newer version) and the SITC (as explained by Tangles) and then install them yourself if you have the knowhow or take them to a tuner and get him to install and tune.
There are heaps of different ways to do this, all depending on price range and what tuner you take it to.
For example I have a Power-FC, which is a replacement ECU, but it had to be dodgy wired in because you cant buy one for a RSFour, but it allows a huge range of tuning capabilities. It would also cost you around the $1500 mark, plus all the stuffinf around to get it to work.
Or there is the GReddy E-Manage, which is a piggyback ecu, but has a lot of features, esp when combined with a Profec E-01. Again fairly expensive from what I have heard, ~$1500........?
Or there are several small piggyback ecu's you can get that do specific jobs, SAFC (Fuel mixture controller), SITC (ignition timing controller), AVCR (boost controller).
It all depends on what either your personal preference is or what your tuners preference is.
Not all tuners know or want to tune all ecu's, I havnt found anyone here in Rockhampton that can tune my Power-FC, mainly because I dont have a hand controller, so they would need to run some sort of program to control the Power-FC, like my old tuner in Brisbane did, meaning if I did want it re-tuned then I will have to drive down to Brisbane for a tune.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
