Hi all,
was at the Melbourne motor show today and in Bay 21 there were these people selling "Stromberg High Frequency Converters". Basically they reckon that when you install these, it triples the frequency of the sparks in the spark plugs, thus increasing the amount of fuel burnt and positively affecting economy and power.
They reckon anything up to 20% power increase, 14% petrol saving, increased spark plug life as well as other benefits.
Here is a URL i found on these things: http://www.geocities.com/surbolabuan/Stromberg.html
Does anybody know if these things work? Is it worth forking out $250 for a set of 6 for my line?
-Max
Hahah not another one...
Nahh man i would keep ur money in ur pocket.
It sounds like a scam, the website is a geocities one for gods sake
And it doesnt even work.
Ive never heard of this brand/product, and without knowing it, i can say its prolly like all those other magic fuel savers etc that do Sweet FA, ie fuelmaser REF Current Affairs Last year
Hey but if u still think that it may work, get it, then get ur car dynoed. If it doenst work, then bring it back for a full refund. U will onlu loose out on the dyno cost.
The link you provided also supply the infamous "Surbo" a known fraud. There's no evidence of any research or studies on how this spark thing actually works & it would appear a good name associated with carburettors is being used in a thinly veiled attempt to establish credibility for a product that has no sound basis - or even explanation - as to how & why it should work... ????
If you want something easy, cost effective that will improve performance and economy, try a tin-based fuel catalyst. these things most definitely work as claimed, regardless of whether you have any other mods.
I'm surprised the motor show organisers let these people in !!
Enrico,
I've had fuel catalysts installed on two different cars - yes they work, just as claimed. They lean out mixtures, as tested on a dyno with EGO probe, decoke the engine, as evidenced by oil that goes black as sh1t after 700-1000k's after fitting, better throttle response and economy + reduced emmissions.
Fuelstar's website now has links to before/after dyno charts, and the tuner had the sensibility to measure intake temps to compensate for any associated power gains/losses. Of particular interest is the XR6 ute, due to the timeline of runs and esp. the 180SX which has the same dip in the power curve that we've ALL seen on Skylines - right as the cams "come on" in kicks the knock sensor. Fuel catalysts fix this without ECU adjustment.
Powdered tin was issued to GI's in WWII, so they could use contaminated or very poor fuel in practically any internal combustion engine - so yeah they work and it's nothing new...
Sorry to rave - a fuel cat will pay for itself in petrol savings within a year if you drive regularly - you even be able to use lower octane fuel. I will soon fit one to the BigDatto and publish the results over a 10,000k period.
http://www.fuelstar.com/whatsnew.html
again, NOT a gimmick.
Hope this adds, etc.
Correct.
Tin, being a soft metal like lead will prevent VSR in "old tech-valve & seat" engines without the toxicity of lead. A Very Good Thing.
The classic & collector crowd have been using fuel cats for yonks - fit & forget. They work just as well on modern hi-tech donks. My old man had a Morgan +8, a tarmac rally Mini & a concours Cooper S... and fitted fuel cats to all of them. Thay made more power on ULP than leaded with no engine mods + reduced fuel consumption.
How many performance mods actually pay you back ???
BigDatto, you say that these catalysts lean out fuel - wouldnt this be pretty dangerous when already running mixtures on the edge?
Have you heard any reports of people using these in modified cars.
At well over the $1 mark for 98ron, these sound interesting, but when you include the cost of a new tune, or perhaps a rebuild due to detonation - I am a bit scared:)
Cheers
Steve
Good point , Steve
From my experience the correction in A/F ratios is subtle compared to a say a programmable ECU or interceptor tuned for a few more herbs, and only if it's required. As for highly tuned vehicles I couldn't tell you.
When I enquired about an appropriate unit for the BigDatto, they posted back this of particular interest:
sounds good to me, but then I plan to keep the stock turbo...
Hi Y'all,
Just saw an ad on the telly for "Today Tonight" (ch.7). One item mentioned was a device which claims fuel savings of 27% and looked very much like a fuel cat. I'll be watching this tonight with interest !!:D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
