...and turn off caps lock...heheheh just kidding mate :laugh:
Liz, im meeting pete (that guy in the mx5...)
at 4pm BP asquith so feel free to meet us then, or out there!
but seriously - run :laugh:
Magazine whore '2RISMO' is sleeping (and has been for weeks). The green monster is Daniel's (aka Beery) car - 'RNMENC'.
It's the one i raced a while back and went 11.7 @ 121mph. The car has seen 124mph before and now has a small shot of the good gear. We'll see how we go.
Adrian
...and turn off caps lock...heheheh just kidding mate :ermm:
but seriously - run :)
thanks, but I'll be coming from work a bit later on.
I'll see you out there!
no running for me :ermm:
