Hey i was wondering if someone can confirm these EBC part numbers for a R33 GTST. Some sites i looked at had a "c" on the end of the red part numbers and some didnt.
This is what i found, im not 100% sure though.
Black
Front - DP1200
Rear - DP826
Green
Front - DP21200
Rear - DP2826
Red
Front - DP31200c
Rear - DP3826c
and i presume the rest would be as follows
Yellow
Front - DP41200r
Rear - DP4826r
Blue
Front - DP51200
Rear - DP5826
Also what do you guys recommend i use ?
The car doesnt realy get track time or anything, but i figure it might be better to go for the yellows if there isnt that much of a price difference from the green and if they last longer.
So anyways your opinions would be great.
And also if someone could please verify these part numbers also that would be great.
https://www.sau.com.au/forums/topic/116874-ebc-pads-for-r33-gtst/
Just another thing, i read that u should get your discs machined b4 puttin ebc pads on. Is this realy necassary?
Im not sure what condition there in but they carnt be too bad, the car has only 40,000 on the clock.
Also how much would it cost roughly to get all 4 discs machined?
