  • Replies 513
Posted Images
What as the cause? Too much fuel in the tank?
Dodgey compliance job. The filler was stuck in with two spots of epoxy only, so there was no seal. I've since sealed it with fuel resistant silicon stuff so it should be right now. I've been meaning to find a corner where I can (safely) hit 1G with a full tank of fuel to test it! :)
Ah cool..
just dont hit a tree/poll :P
