Heyaz
Any way a while ago i bought a pod filter and a adapter for my r32 gts-t type M and have just been looking for the time to make up a cold air intake box for it. But i have been reading and it seems that quite a few people running reasonably stock gear, havent bothered with the air intake box (although a couple of the people are running new turboes, injectors etc.) They just have the pod in the engine bay. So, a pod sucking in warm air, sucks enough in to make it better than the standard panel filter, sucking in cold air? I would prefer not to go to the trouble of making up the intake box for my pod, but i will if its worthwhile (cant afford to buy 1) If any one wants that re-worded just ask, im not so smart :O
Also is it worth putting some custom or aftermarket exhaust headers on it? It has a 3 inch turbo back exhaust, but standard exhaust headers. Am i likely to get less lag or faster spool or moor KW out of em?
Thanks, sorry about the annoying questions but i have looked around and cant really find specific answers to my questions.
you don't have to make a full box for it. just 1 wall to stop the hot air getting to the pod. i have a pod and i have a duct coming up from the intercooler pipe hole (i have a front mount so i have an empty hole) and i'm going to put the factory cold air snorkel back on and just have it sitting on the pod, and just make a single wall up to stop the hot air. that way i will have 2 sources of cold air.
http://img456.imageshack.us/img456/9962/r32carsm2ph.jpg
So lets say i had it hooked up like that, coming off the turbo, i would then make a heat shield (out of aluminium) going diagonally from the [wheek arch] to the side of the pod filter to block off rising heat from the engine, and leave the back and front of the pod open, with my standard cold air intake in the same position
right? or wrong
Edited by 32thrasher
yeah sort of. i have the standard intake, i just have a pod where the airbox was. go here http://www.uniqueautosports.com.au/ and go into parts catalogue, skyline gts-t, engine. then most of the way down the page there is a UAS cold air box. the pod sits in that. basically all you need is the vertical wall.
thanks so far, but another annoying question, what do you mean, have the factory cold air intake sitting on top of my pod? Do you just mean have the factory cold air intake, inside of the partition, facing the pods general direction?
Thanks for your help, so far :ermm:
the yellow line is about where you would put the partition, and the green represnts the top half of the factory airbox and snorkel.
the pod is under the green bit.
Edited by mad082
i'm having one of those days too. you'd probably want to make the partition out of a heatsheilding material rather than aluminium. any metal will just absorb heat and won't work as well.
you can get stuff for exhaust shops that works really well, but it costs a bit. but if you could get your hands on some high temp plastic, or a square of fibreglass, that would be ideal.
i'm going to make mine out of firbeglass and then go the the wreckers and get an old bonnet lining and put that in there for extra heat protection. if you do make it out of alloy i'd do the same.
r32's dont have a snorkel on top of the airbox like an R33 ...
the cold air intake comes from behind the passenger headlight and comes out of the guard into the airbox..
so yeah, might wanna consider that
So all your saying is if you have a R33 like me just buy the UAS fibreglass cold air box and keep the standard snorkel is that it?? wouldnt that just be pointless??? The air from the snorkel would not reach the pod in the UAS box.
heyaz, i just installed 1 of these things ( yet to add a partition for cold air) into my 32 gts-t and wow. I didnt think it would make any difference but the difference is huge. I dont know if the sensor just inside the intake had a loose wire or what but i added the pod and now i get my turbo spooling at 2800 rpm instead of 3000 rpm and it holds boost almost to 6000rpm at which stage it drops boost, instead of dropping .2 bar the second it hits 5000 rpm.
Makes the car sound a like its got a BOV or something, the pod noise is really damn loud. (not sure if im to keen on it)
thx 4 ur guide mad
Edited by r32 gts-turbo
nahh, just a pod and made a partition out of 2 peices of aluminium with some heat obsorbing material in between (split pins to hold the 2 pieces of aluminium together) a bit dodgy :unsure:
i wasn't saying buy a UAS one and leave the stock snorkel on. 32 thrasher didn't understand what i meant about a partition. what i'm saying is put a partition up and leave the factory snorkel. if you buy a UAS box you wouldn't use the snorkel unless u cut a hole in the box to feed it into. the problem with the UAS boxes is that if you have a stock cooler or a cooler that uses both stock intersooler pipes, then the box doesn't get very much airflow to it, unless you start cutting holes.
and i didn't know r32s didn't have a snorkel.
Edited by mad082
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
