  • Replies 48
coilvers are a whole strut/srping replacement.
basically its a perfectly match strut and spring, but all gives you things like hieght adjustment, damper adjustment(how hard/soft the bounces are) and high end ones give rebound adjustment too (how much it bounces)
personally, id reccomend the D2's for a good cheap street coilover.
teins are quite stiff, however they have just released a 'softer, australian version' they are still quite expensive.
ive got teins in my car, whilst it handles like a dream on flat surfaces, find some bumps like a normal road and it can be quite a handful.
ask wilkys what they reccomend coilover wise for a street driven 2 (i assume you dont take it to the track much, if at all) and get a price off that.
getting springs may be all you need, i dont know how 'hardcore' you want to go with your car(track/street/show?) but coilovers are definately a good handling mod.
https://www.sau.com.au/forums/topic/117295-permits/page/3/#findComment-2397033
my car was used for a bit of drift over in jah-pan.
so it came with alot of adjustable goodies.
coilovers are a good choice if thats your plan, but then you can always get the springs, and sell them at a later date for a setof coilies.
https://www.sau.com.au/forums/topic/117295-permits/page/3/#findComment-2397041
dude dont waste 600 on suspension that your just gonna replace soon just fork out extra and get some d2s the are about 1500 1700 fitted they are alrite coilovers i got them on my car i got the track ones u can get street, rally, and drift ones pretty much all at the same price u can adjust the dampener and hieght which is quite kool and if need be you can raise the car like a 4x4 or dumped in the gaurds (like me not good only good for shows bad scrapage in normal daily use)
https://www.sau.com.au/forums/topic/117295-permits/page/3/#findComment-2397547
Call them up and ask. Speculating isn't going to get you permits.
Since I have been over the pits a few times already, the dude has said
"You are not getting this car on the road with out permits for: ... ... ... ... ... ... ... "
https://www.sau.com.au/forums/topic/117295-permits/page/3/#findComment-2432532
Hey i just rang up the licensing centre regarding legal wheel widths and apparently theyre a bit flexible on the width just as long as the track distance doesnt change more than 25mm. So if i get some wheels with the same offset as the factory wheels my track distance should stay the same regardless of the wheel width, right?
https://www.sau.com.au/forums/topic/117295-permits/page/3/#findComment-2438314
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
    • Do you have any before and after photos? That's $200 just for the hydro blasting?
    • It doesn't look like there's a lot of options out there these days, and what's out there is performance oriented aftermarket stuff (with the GTR markup) I wonder if there are other cars with similar springs, after all its just a matter of length, diameter and stiffness. Alternatively, I did see coil spacers. Probably not the best option, but could be serviceable too.
