Last week i got my Blitz Intercooler and i thought the piping came polished, to my disappointment it didnt and the finish looked very ordinary.
Below is a pic of the piping AFTER i sanded it back with wet&dry and gave it a buff. Just interested what you guys think, and if anyone would like me to do theirs for them.
Or plenum etc
Just out of curiosity how much does this usually cost to get done in a shop? I want to know what i saved doing it myself.
https://www.sau.com.au/forums/topic/117409-polishing/
i like it.
When you sanded it back what grade of paper were you using?
Also for more coarse surfaces like crossover pipe/plenum.should a more coarse wet/dry paper be used to penetrate?then get it smoother with the smooth stuff then buff??
When they bent the pipe the outside 'stretched' and went all rippled so i had to start with 600 grade paper, then move up 800, 1000, and finally 1200. Took a while to get the bumps out. but yeh you need to get a smooth flat surface before you start with the finer stuff otherwise it will take you weeks to get any results with 1200 grade paper, then if you have access give it a buff to make it nice and shiny. If you live in Sydney i can probably give it a quick buff for you.
https://www.sau.com.au/forums/topic/117409-polishing/#findComment-2191123
Thanks for the offer,but i allready have a buffing kit.:P
Thats the sort of thread im after.:)
https://www.sau.com.au/forums/topic/117409-polishing/#findComment-2201628
It's a pritty ensane friend, when i first saw it i sent it to all my mates who woudl be interested in this thing and had the email topic
"Someone needs a girlfriend"
HAHAHA alot of time must of went into it cuase he says i spent 4hours on one little section or somthing. LOL
Crazy, but excellent end result!
https://www.sau.com.au/forums/topic/117409-polishing/#findComment-2201940
Excellent link... has just given me some more ideas... made my attempt look shit though :)
Ahh well back to the workshop!!!
https://www.sau.com.au/forums/topic/117409-polishing/#findComment-2207182
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
