A proper GT30R unit number 700382-12 would work better with that .82AR turbine housing . GT3040's particularly the Garrett marketed one's are laggy because the GT40 compressor is too big for the GT30 turbine . A better compressor match is the GT37 series wheels used in HKS's GT3037 and that above mentioned Garrett marketed GT30R . In fact that GT30R uses the identical cartridge (CHRA) as HKS's GT3037 56 trim .
Many turbo shops try to say that GT30R 700382-12 is not available in Australia which is B/S , I know Brett from GCG can get them as no doubt others in Aus can if they try . Garrett at Chippingnorton may not stock them but not all Garrett turbos here have to be sourced through Jeffs joint .
Cheers A .
we run .82 on customer cars, start building boost at 2800rpm and see full at 4000rpm. very streetable and run 11.75 @ 121mph at track. lag will also depend on boost controller and intake runner length, cam timing, overall tune. I think 1.06 would be good for track if your on the bottle, otherwise too big, definetaly not streetable.
as my heading states.
just wondering when boost would be likely to come on. looking at getting a gt3040 with 0.7front,1.06rear housings. has anyone got this on there car.
cheers dan
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
