hey guys, im wondering if anyone could shed some light on my prob. i replaced my rear left wheel bearing the other week, but i still have a vibration from the back of the car. howls at 60kmh and 105kmh, otherwise good. but under hard acceleration something is vibrating. im think tailshaft or drive shafts out of balance?? any ideas would be great!
Bill. :P
https://www.sau.com.au/forums/topic/117763-funny-vibration/
