can you please explain what you mean hence,you have never seen my car before?
The reason for replacing everything is if your going to do something do it properly!
and the only reason the engine went was a bad aussie tunner. but hence dont go there anymore!
but now rebuilt stonger than ever well has been for the past year!
this car looks like it had bad damage before or a bad time
https://www.sau.com.au/forums/topic/117927-sold/#findComment-2211217
Works fine :D
Scroll down, and click "browse" to find the pic you want to attach, and then click "Add this attachment".
It will then upload the file to SAU.
https://www.sau.com.au/forums/topic/117927-sold/#findComment-2214309
  • 3 weeks later...
