Ive got some skyline parts i needa sell
-Standard Clutch Fan RB25 $50
-Series 1 RB25 Radiator $150
-GTST air con pump,Condensor,Radiator $180
-Veil Side Front Bar Black $300
-Standard Bar (needs to be resprayed) $60
-Series 1 Wing $80
-Air flow meters(series 1 & 2 ) $50 ea
-Series 1 ECU RB25 $100
-RB25 Coil packs X 6 $150
-GTST front Guards Black Good Condition $300
-Polised Tappet Covers with Catch can & speedflow lines Brand New $750
-R33 Strut Brace Blue New $100
-Black Aftermarket Wing New X demo $250
-Standard Fuel Tank GTST $100
-Redline Bonnet Lock Pins $22 NEW
-Oznos Line Locker $240 NEW
-2 X standard RB25 Throttle bodies
-RCI roll cage Padding $6 a length New
-MT 10.5x28x15 Slicks 4 passes old $280
-RB30 Block, Crank,Rods $300
-300 ZX Standard Air filter box $100
-WRX 2000 strut brace $100 NEW
-Simpson Race suit (carnt fit into it)XL suit and Shoes Brand new $350
-Motive 3.5 Gears to suit Ford 9" New $240
-Civic 92" Altezza Clear tail Lights New $220
-Lancer 96" Altezza Clear Tail Lights New $250
-Ford 9" standard 28 spline LSD centre 2.75 gears $300
-RCI fuel caps fillers NEW $60
-Standard skyline Dump pipe to cat $50
-200sx S14 cradle (damage lower controll arm) $200
-GTR R33 Rods (shot peened,ARP rod Bolts) $400
-Sparco 17" race wheels With tyres 90% tread front Needs new rear $1000
Used gauges
-Splitfire 2 1/16 Oil press silver $50
-Autometer 2 5/8 fuel pressure with Isoslator 0-15 psi $140
-Splitfire Rev Tacho Missing shift light and Brackets $60
Some split fire Guages im selling for someone
-2 5/8 Trans Temp Silver Electric $80 New
-2 5/8 Trans Temp Black Electric $80 New
-2 5/8 Oil Temp Black Electric $80 New
-2 5/8 Fuel 0-15 PSI Mech $70 New
Pro 7 colour 2 1/16 Vac Mech Guage $50 New
For photos PM me
All Parts are negotiable to a certain Extent
All Prices are (+ Postage)
My mobile is 0424 337 243 if any one needs to contact me Ask for Jason
Edited by MR331307
-Ross Flywheel Brand New To suit RB25,RB26 Chrome Moly Lightened $400
-GFB Mach 1 BOV Used $120
-Series 1 RB25 Radiator $170
-Series 1 Wing $80
-R33 Strut Brace Blue $100
-308 New alumium tappt covers $200
-Lancer 96" Altezza Clear Tail Lights $250
For photos PM me
i'll give you 80$ for the strut brace, rear or front?
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
