hi guys
I have these up for sale as i will be selling my car shortly and have put the stockies on for the sale. They are like new with only one minor gutter rash as shown in the pic (almost cant see it). The rubbers are all quite good still. The "Pirelli 6000's" at the back have more than 60% tread, the "Maxgrade II" tyres at the front have about 40% tread. These are on the current RAYs wheels catalogue and can be found at their website www.rayswheels.co.jp/indexe.html
The tire dimensions are:
Front: 235/45/17
Rear: 255/40/17
All other specs on the RAYs wheels are on the stickers, which are:
Front: 17x8 rims with +35 offset
Rear: 17x9 rims with +37 offset
114.3 PCD
Suitable for R32 GTST, R33 GTST & R34 GTT. Should suit 200SX and many others!
Rims located in Melbourne, pickup is preffered (Springvale South). Courier to other states possible but at own cost and you will have to organise courier pickup from my address.
Call me on 0410 689 203 for any Q's.
cheers,
Michael
Edited by Driftn 180
interested in a trade plus cash? I have some gunmetal grey BBS 2-piece 17's (same specs as your rims)..
let me know, those Volks are awsome!! I'm really looking for these in 18's but hey.... if your willing to trade+ cash I'll be happy with 17's.
Cheers
Berin
(pics of my rims are in my gallery, link should be somewhere under my avitar)
  • 1 month later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
