Hi to all,
i need some advice on a problem which by other post sounds quite common in 34's
let me first infom you what i have had done recently to my 34gtt $ 6500.00 later i have my turbo hiflowed with trust internals from GCG, 550 cc injectors, apexi power fc computer,full hks super drager exaust,front mount, dump pipe, runnin 16 psi,walbro 255 lt pump, only just put in thinking this may fix my problem.
ok here is my problem when at hi rpm say 3500 upwards and anything above 10 psi i get pap pap pap sound like a boost cut sound some times it runs good and some times it runs bad, it was tuned in brisbane and all went fine untill i return home I'm about 900 mtrs above sea level a bit colder temp as per say.
if anybody can help me with a solution or advice my mechainc says it now could be coil packs and recomends split fire items at a Cool $ 1000.00
any help would be great thanks heaps ...... :
https://www.sau.com.au/forums/topic/118341-bad-miss-at-hi-rpm/
could be a coil pack issue.. i have the same thing happening
try dropping your spark plug gap to like 0.6mm and see if it helps
mmm good point, i will have to try that thanks...
it is set at 0.8 at the moment from 1.1
it is a pain in the butt hey...
Yep.
It's coil packs.
I wouldn't go much further than 0.8mm gap though.
Don't buy the Splitfires at $1000 though.
You should be able to get them for about $600 odd from Greenline, Nengun or Kudos Motorsport (group buy specialists who I got mine through).
Souonds like you have done the right stuff with your mods.
Where's you dyno chart? We want numbers!
Yep.
It's coil packs.
thanks bass junky for the info,
did you get your coil packs local with local people or did you order them from an over seas mob and then sent to you. i looked at the 3 you said and i think kudos boys are local to order from gold coast i think..
any help on the matter .. im trying to get them in AU at the best price if possible. :D
thanks heaps
Gapping down the spark plugs is a cheap fix, it just makes the spark work across the plug because the path of least resistance again becomes the spark plug, rather than the block where the coilpack usually arcs out when they're not working properly. By gapping down the spark plug you're reducing the area of burn and this can be seen as an inefficent use of burning fuel. In the long run, you're much better off changing coil-packs and running the gap as close to 1.0 as you can.
Those of us who have been around a while have seen this exact problem many times. I could have told you the answer to your query just from the title of your thread.
If you gap them down to 0.6 the best you will have is a temporary solution.
Get the Splitfires and be done with it. Stock GTT coils are shit. $1000 is a rip off. Should be able to find them for around $600ish.
Oh and ditch that crappy fuel pump. You are playing with fire there. I'd hate to see you lose an engine through trying to save $100 on a the fuel pump. Someone with lower power aspirations will buy it off you as I would still recommend it up to about 230rwkw.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
