  • Replies 82
Well, the person at Wakefield said they will wait until about 530pm for us
But if theres a problem getting there around then, we can work out something - like i send you the paperwork (easy, just name, address etc for their insurance) and you can either send it completed back to me, or direct to them. Then i can collect your key when i arrive and you just call me when you arrive and i walk to the gate and let you in :thumbsup:
I made a second payment of $100 for the 2 extra people. The payment reference is "Jon Bates".
Could you please check its there?
Cheers :P
What date did you make the extra payment?
I cant find it in there
