can i mention that it takes alot longer then 15mins to get to nudgee from springwood crazy clarks.
maybe for you :)
its ok these are approx times. I'll be in contact with the groups and we'll wait till everyone's there
  • Replies 248
Posted Images
I'm in as always:) Can we have a city area meet up in Milton maybe? coz I have no idea where nudgee is, besides, it will be more fun cuising there with other skylines.
Mud....
I can lead the milton group if you like as milton is closer for me then meeting those at springwood.
consider it a deal. call must be placed within a 5 minute window of 6:20am to qualify for 1kg of M&Ms.
Doneded....so based on your criteria I can call between 6:15am and 6:25am? Thats within the 5 min window of 6:20am, unless you say it must be after 6:20am...
We should sync our watches
Do M&Ms look the same on the way out?
Eeeeeewwwwwwwwww :D
h guys
i'm new out to make new friend so me and my 34 should be there....
Hi There,
Would be good to meet you. Cya there.
And Karen,
You are correct, between 6:15 and 6:25am and we should sync our watches.
At the beep it will be 4:11pm
BEEP.
Mark,
Marc and I will lead the Springwood group if you haven't got anyone else yet.
BTW is there anyone from down Springwood way who is actually coming on this event, coz if there isn't I'm not going all the way down to Springwood from Toowong and I will lead the Milton group instead :)
Milton group can meet at the BP on Milton Road :)
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
