Hi All,
The time has come to move on. Spec's are.
R33 Nissan Skyline RB25DET - 90,xxx km Timing belt replaced by protek
Exceddy heavy Duty clutch.
Heart Racing Deep Dish Racing Wheel.
Nitto Tyres on the Rear 18*9 and on the front 18*8
3inch dump pipe to twin Fubijsto Exhaust
Blitz Pod Filter kit.
Biltz Boost Guage
Drift - Oil Pressue and Oil Temp Guage
Lovells Springs and shocks - Lowered to 110mm.
400R Skide Skirts and Rear Pods
Full respray in House of Kolor Candy apple red.
Car is has been serviced regualar basis with Motul Oil.
Car has never been boosted and only driven about 4 days a week.
Asking 18,500 ono
Price Drop to 17,500 ono
Edited by davidl
https://www.sau.com.au/forums/topic/118812-fs-1995-nissan-skyline-gtst/
Car looks awesome!
Love the colour ;) (looks like mine :D)
Shame we never seen you at a cruise :(
Good luck with the sale
Thanks mate, yeah haven't really gotten into the cruise scene, not sure why.. maybe I will turn up..
Cheers
David.
Also located in Melbourne
very very interested. where u located. sexy car. mate im all seirous for a car and this is too perfect. waats the lowest you could go on cash, my email is [email protected]
Don't think he accepts VISA or Master Card :P :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
