Aight boyz I sold my skyline so got to get rid of all the crap laying around
GTR N1 rear lip perfect condition in 2 pac metalic black $200 (the one that sits on the boot and can retain original gtr wing aswell)
GTR wing original black(not a copy) $100 needs a few chunks bogged up from storage damage
Air flow meter $50 in perfect working order r32 rb20det
R32 gtst alloys brand new tyres $120 each just for tyres $500 225 50 16 (with the wider tyres looks like gtr wheels)
r33/s14 alloys full set 2 tyres are bald and 2 are 40% $250
Hicas lock bar for r32 gtst bought from garage-13 $150 still in packaging unopened
Go Fast bits atomic boost controller $40 used blue
R32 gtst white dials for dash never used $50
Standard intercooler for r32 with some piping $50
R32 gtst standard airbox includes panel filter $150
Massive canon old $50
all stuff in Ingleburn Sydeny .....
0411197845
Anthony
Picks tonight just Pm what you want
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
