hey
im selling a t3 turbo, legit garrett, not a copy of any sort
oil cooled t3 flange
0.63 rear housing
currently externally gates but flap is still there to run internal gate if you wish, has cast dump pipe
$300 ono
cheers
ryan
0410 332 673
Edited by RU34ME
https://www.sau.com.au/forums/topic/119235-garrett-t3-turbo/
can run it on a r33, if you want internal gate, put the actuator off your standard turbo on it, if you want an external gate, i will throw in a 38mm external gate for $50
do u stil hav the turbo wat condition is it in shaft play etc and also where r u
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
