yeah im gonna keep the stocko one, but il just wanna geta hi flow one to replace the standard one anyway. i just wanna keep it all legal. i mean really im not at the point withthe car that the flow is gonna be affected that much with a hi flow cat there or bash out one. it doesnt really matter to me.
haha thats gold
i must ask, y do you want the entire exhaust system stainless? i mean its not like itll be seen at all
well the car came with a kakimoto cat back stainless exhuast on it, and now i have just got a front pipe and dump pipe that are stainless also, so all i have to get now is a cat, so why not just make it stainless aswell. to finish off the exhuast
I had no choice for my exhaust modifications.. Andrew had the car one day and came to pick me up from work and it was like 10 times louder.
yeah i have seen ppl put a straight thru pipe into a cat and weld it on so it looks like a cats there. im just trying to think how different it will sound with a fullsystem. so far ive managed to get away with thefront pipe and dump pipe all in stainless for $200
fair point
i picked up my new bottom end today :)
will be pulling out the 26 tomorrow and pull the head off to see what actually let go in it. then the 26 head and 30 bottom end are off to JHH next saturday to be built (fingers crossed nothing goes wrong)
if all goes to plan itll be back on the road in 3 weeks time, making some big numbers ;)
Is it worth spending that much money though on something that will do the same thing as something cheaper?
Is there really any benefit in getting a stainless one? Is it less restrictive?... Gains more power?... Not much difference at all.. just looks shiney?
fair point
so did u break the GTR already?? what happened??
id say there is no difference between stainless and mild steel, it just wont rust out, but since i have the system all the way from turbo to bumper in stainless, why not just get a cat to go with it. plus if i got one without a flange, i dunno if they can weld stainless to mild steel or not?? im not sure on that one.....
yep broke a few weeks ago whilst i was going to go for a drive with ben & dale
starting knocking at the toowong roundabout, turned around and made it home, knocks like crazy now though. we think its bearing related, find out for sure tomorrow :)
managed to pick up a recently rebuilt (200kms on it hone marks in bores still present) 30 bottom end with forged pistons (20 thou over) n1 oil pump, for $650 hehehe
so are they gonna bore it out then put over sized pistons in it???
nah thats already been done, just need forged rods, decent bearings. heads getting ported, exhaust side ports are getting re-profiled, whole thing balanced, sump being modified with a trust enlarged sump, oil galleries being fixed up appropriately for track work etc etc
sounds like your gonna spend a bit of cash on it then...... its hould be mean :)
yeh it should pull pretty good ;)
i only brought the stocko engine onto boost twice! i drove it back from newcastle off boost the whole way caus the clutch was stuffed that bad, then after putting the clutch in i smacked it side on into a gutter bending the left rear control arm, then the sat i got that fixed the engine let go
going to leave the stock turbos on for awhile and see what power i can get out of them, then i'll go the gtrs's :P
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
