i have the hardest tme cooking for myself, last time i was by myself i somehow turned a packet hamburger into mince :P dunno how though and i made these awesome toaster sandwhiches that took me ages to prefer, and i burnt them to shit in the sandwhich press :no:
ha ha im not that bad lol i can cook,
im just too lazy to do it, and it ssuck when u are preparing a meal for 1 person bcoz u got a lot of trouble for 1 meal it sucks, or u cook enough for 5 ppl in one go then end up eating it all for like 3 days lol
Edited by 85URK
wow, cant believw you tube was started by teenages, who are now billonaires. i wish i had thought of something liek that
on the news they were like 27 year olds..... but yeah its crazyto think of somehting as simple as that and become a billionaire.
what are they gonna call it now??
GOOGLE TUBE!
yeah,, i normalyl jsut eat out for almost every meal,. parents leave more than enough cash,, or i cheat them by eating at home and poceting it all :P
i get sick of take out after like a week.
plus there isplenty of food left for me to cook, no need to waste it.
GOOGLE TUBE!
hmm weird,, thing i just heard said teens.. very wierd
Ma VC haz a prob hear is teh mssn thic whats wrong wif da car
Dazza says:
dam.....im out of bundy......can u plz go get me some
Bazza says:
nope, i drunk the last of ours a couple of nights ago
Dazza says:
all the bottelshops are closed too
Bazza says:
dont u have any goon in the house?
Dazza says:
ohh.....wait i got a few bottles of metho here
Dazza says:
$2 metho is a bit cheaper then $15 bundy
Bazza says:
so sayeth da black fellaz
Dazza says:
lol....maybe a can fiphon some fuel from my car
Bazza says:
ram raid ftw
Dazza says:
naaazzz da vc is in da shop bro
Bazza says:
ahh f**k, wat da problem now? f**kin carbs need adjustin?
Dazza says:
da mechanic sayed the injectors r seizd.....the methanol musta f**kd it
Dazza says:
na bro says da vc has da same engine as victa bray and he runs methanol
Bazza says:
daz rekon dat happenz when u run carbs an injectors...
Bazza says:
his mate had the injectors runnin fuel
Bazza says:
and had nos ported thru da carbs
Dazza says:
fuel is for weak ford......real men run methanol
Bazza says:
sounded sweet mate
Bazza says:
i run avgas on da cortina
Bazza says:
pffft.......its a ford it dont compare to da vc
Bazza says:
with da red panels on da back ppz at da airport fink its a 747 so its all good mate
Bazza says:
na cortina was made by shelby
