lol wats up now andy?
Stoopid over heating, And I need to drive to Sydney!
And I need to buy a new cat before the tune (I have known that for a long time) And I cant decide what to do Re the radiator
well if u've got overheating problems, ud wanna get that fixed before u hit the track. if u've got the coin, go for one of just japs $399 radiators. that way u wont hav to worry about it ever again. or it could be to do with ur thermostat? prolly check ur thermostat first, see if its opening properly (pull it out, put it in a saucepan at the temp its spose to open, and see if it does actually open)
those catco cats off here are good :(
P.S i checked the front wheels, and none have lock nuts, bunch of tools :sick:
Eddie - have not seen you out cruising around for ages, hows the car going?
laters dan
(60NER)
Being Rebuilt atm Mate, have no seen u since i bumped into u in the city with those chicks u had with u hahahaha
Skyline will be back soon Full RB30DET, Gt35r... pretty massive setup...
I was thinking one of them and I got a super special Pedros cousins sweet hookups price on one from JJ...but then I was told they are infact crapper than the stock ones :( Hence why I am stuck with what to do!
I got a super special Pedros cousins sweet hookups price on a catco from JJ :D
The one at the very bottom of this list http://www.justjap.com/parts_nexhaust.htm
what can i say, given the situation after what u tryed to do with my missus i guess u have to laugh it up.
LOL! here we go! more cod shit.
dude, get over it. nothin happened.
but seriously, you should go back to cruisingbrisbane and pm a few more chicks to offer your helping service on there and lend a hand in exchange for those roots you ask for after working on their cars.
LOL! mods are having a field day with you on there.
PS I knew it didnt have lock nuts >< Damn loosers
Hows it going anyway? All good?
lol yeah, cant believe they reckon it did *shrugs*
yep its all good, gonna ring em up in a min to see if they're done. they've got a few nice race cars in there, a lotus elise, some GT car
Wicked! Those Tyres should make it a bit better to drive!
Now all it needs is a clutch lol
Ooo I like elises...exige is better but
yeh i could hey, f**k yeh pick up some 14 yo old broad minded persons root em then toss em your way?? although rape isnt my thing John... but we ( me and my gf, and the 2 other chicks u tryed to do it to ) will all agree that its ur style.. if u have anything further to say mate take it to PM
Hey Bunta!
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
