onyl real problem im having, is where to relocate the horns, and washer bottle
and putting everything back together :ninja:
Just keep shoving it all back in there till there is nothing left........Actually no dont do that
THE LINKS TO THE CARS ARE FOR A CHINESE COMPANY (BASED IN HONG KONG WHERE MY FRIEND LIVES) SO THE 5.5 IS SIMPLY WHAT HE TOLD ME HIS MONEY IS WORTH EVERY YEAR WHEN HE COMES ABCK TO AUSSIE
Yeah my mum drinks that, its not bad either, i alos tried a redbull vodka at my mates wedding the other week, there pretty tasty too.
And when can you ever have enough of BOOB cruising?
that would be what is called a Jaga bomb (have half glass of redbull and drop shot of vodka in and smash it down:D)
6.15pm or so...i dunno where finchley street is though
I can find it though...I'm not useless...I will call you if I'm gonna be late :)
whereis is ur friend :)
new office new number, 3721 6331
and putting everything back together :yes:
horns cna go nywhere dude, and u can also get smaller washer bottles :laugh:
who said anything about YEN? my friends chinese, we are on a CHINESE WEBSITE
oh, my bad :ninja:
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
