treads international is northside???
yeah way northside, up near redcliffe but it is well worth it, just ring to make sure they will be there because they make deliveries and sometimes arent there all day on a saturday
HI5
PS the muffler isnt a rice cannon that every man and his excell has, it attracts no attention and still flows the same due to the fact that the cross section area is the same as a large tip....if it fitted the R32 I would have swapped in an instant, the R32 one shits me no end
f the flow, its the sound ur after :rofl:
Tredz international
I got bridgstone tyres in pretty good nick for $80 each
Where as new crap nankangs were going to cost over $1000 these prices are for 18s but
But tredz dont fit so you will have to book someone to fit them too
and not to mention they were 265 wide :O
ok, should get the car back from dan tomorrow night.
i`ll check the tyre size and give'em a call wednesday to see if they`ll be around on saturday and if they got my tyres in stock.
thanks andy :rofl:
:O
Riciest statment of the day award goes to.......shane!
i was waiting for that...but come on, why would u want to hide that lovely note of an RB? :O
Also, when u have a stuffed clutch, if u have a louder exhaust, u can hear when its going to slip much easily
Shane when do you get your adaptor plate?
supposodly today, i'll be ringing them this arvo to see if it's done. and fingers crossed it fits and i dont have to alter it! (or i'll be pushing to get it done b4 the weekend)
I take it these are imported tyres?
depends if i cant get my mates hoist ill have to do it on the ground again, and then if the box wants to play ball when it goes back in :P.
NISSAN, what car, engine & gearbox is it for? ill make a call
all u need is a new throwout bearing (which should come with the clutch), no need for a pivot, and wtf is a needle roller :laugh:
its basically for Rb20 engine and gear box from an R32......
cool i'll check when i get the clutch, if i get that bearing.....
They sure are!
BTW I think I want this
A garrett GT30R on a rb25....and that one has no cams
Chances are they are not legal in australia then. There are alot of places doing this but they dont meet our standards, so my advice would be to check them out as it probably would void all insurance.
Nice graph, thats the turbo i was looking at.
the ones I got are bridgestone S03 and 2s standard issue on HSV's :laugh: so they comply
There are many specs on GT30s...that one is the .63 housing, anything bigger is too big so make sure you get the right one!
i'm lookin at actually gettin the GT35R turbo for mine.
wantin around 250/260kw's atm but with the bigger turbo, can always get more power later on once i feel the need for more.
A gt30R will be heaps enough for that goal and with higher boost it will do over 300rwkw with much less lag than a GT35R
If you look at the graph the GT30 is making 270 on only 15psi
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
