dammit theres no farking full cream milk, no my coffee tastes like sheit :D
gotta hate that, i'm a bastard to work with if i'm forced to drink shitteh coffee :thanks: worst when theres no milk at all :P
yeah and to make things worse, the fridge is full off the no fat shit! like u know how theres full cream, and then 'trim', and then tehres that 'slim' stuff, well like 15 bottles of the 'slim' and 1 bottle of 'trim'
yeah wtf is with ppl that drink that, its like white coloured water! some labs i work in they can have up to FIVE different types of milk to cater for the staff, all the low fat shit but no proper milk :P
sif ur gunna put on 4kgs just by having like 20ml of 'fatty' milk in ya coffee, stupid women :D
and yes shane you've struck a raw nerve- its kinda a pet hate of mine, i'll send you a sympathy card :thanks:
Cha-Ching :D
talking about milk issues @ work and you come out with that comment :P
bahah i didnt intend it to coincide about the milk issue...
i want to go home *jumps up and down*
Yeh you did bish....sad attempt at monday morning humour :thanks:
Oh wells what I can say, I laughed too :P
Me tooooooooo. I wanna do another mountain run...that was a lot of fun...except the joker in that old heap of crap ute/hilux thing :D
Yeh you did bish....sad attempt at monday morning humour :/
Me tooooooooo. I wanna do another mountain run...that was a lot of fun...except the joker in that old heap of crap ute/hilux thing :thanks:
yeahhhh and this time i wanna drive *cries*
heh shoulda went up to him and had a little talk, caus hell i know i woulda if he was infront of me :w00t:
i trial fitted the engine last nite karen, u should see the blue engine contrasting with the purple of the engine bay :D
heh shoulda went up to him and had a little talk, caus hell i know i woulda if he was infront of me :D
i trial fitted the engine last nite karen, u should see the blue engine contrasting with the purple of the engine bay :P
PICSORBAN....infact just BAN :thanks:
PS: post pics on your way out
PICSORBAN....infact just BAN :D
if i had some to post i would dont u worry...i'll take some tonite, caus i gotta drop the gearbox to sit it in properly. putting all the lines back on, i've discovered that a few turbo lines have gone missing, dont know how, they musta just got up and ran away :P braided lines it is then!
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
