anna ur sister is going to kill me, does she have an achillies heel? :( i'll need to defend myself when i get back to work :)
I KNEW IT!!
now i'm gonna hafta listen to her bitch and bitch on the phone about it!
GOOD ONE YOU'VE KILLED US BOTH!!!!!!
bahahahaha that may be so!!!
but you love bukkake....... so you're gross bahahaha :(
bukkake....isn't that the sound a chicken makes.. tisk tisk tisk lee youre a sick man with a myriad display of fetishes like a peacock displays his feathers
I KNEW IT!!
shes going to beat me again :(
i'll hold you if you hold me :):)
i'll hold you if you hold me :);)
get f*ked i did nothing wrong!!!!!!!!
bahahahaha
you're in this one alone sorry buddy, i gotta save my lifelines for when I borrow something of hers and break it or need to hit her up for money...
LOL
come to think of it she told me yesterday
'f**k the company, i take all my sick days and half of those were pretty much sickies', so guess she's pwnd herself by convincing me to take time off
what on our massive scientist wage levels :):(
yeah only suckers take their sick days off when their sick though........
u go to work sick and do nothing and get paid for it, then when you're better you take the day off to go have fun :(
why have u seen his wang?
LOL
:huh:
as a matter of fact.... :no:
but he has told me :)
Me??? :O otay i do :yes:
i'll hold you if you hold me ;);)
:) thats the worst pick up line i've ever heard...... does it work???
no pick up lines, no balls... that's my policy
why bother when u can get straight to it :huh:
jokes
a policy like that only leaves u a long single life like shanes
didnt u ask me yesterday to ahve a look at ur wiring problem john? :)
no balls....
no pick up lines....
Shane would be perfect for you....
but i hope you like small wangs ;)
it still gets u screaming :yes:
bahahahaha we can't all love balls as much as you do ;)
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
