U know I am baybeh!!
I'll be there AND be square!!
(simpsons, bi-mon-sci-fi-con.. LOL I bet hardly anyone gets that)
*Raises hand* I remember...ALF was at that convention
Andrew what was I referring to the other night when I just yelled out bi-mon-sci-fi-con... FARK i can't remember now :laugh:
:laugh: true. stupid womens rights movements
*runs and hides*
Nah No need to hide. I f**king hate feminists. All that 'equal rights' bullshit. EQUAL is fair. YOU getting more rights than MEN is NOT fair you hairy muff diving sunuvabitch! :laugh:
It shits me so much because for the last 2 years i've had to listen to countless reports of women who've struggled to be seen as equals to men. And then they go ahead and endorse women's only associations, such as fernwood. I tell you what, if someone started a gym for men only there'd be hell to pay! And why? You'd go there once and never go again. What has that achieved. NOTHING. Go and spend your precious time and money on something useful, like getting your back waxed and removing your well overdue tampon you scrag.
*sigh*
She has to go to court also by her self to get our tenent evicted from our house at Chermside because he has not paid rent in weeks... "AGAIN"...
So i fell sorry to put extra strain on her...
Well I know I can't help her with her court stuff, but if she'd just like the company and support i'll be more than happy to accompany her :laugh:
I have an asian chicky for ya, but it's a bit rude....
:laugh:
nothing ever too rude :)
doesn't the song on Nova sound like it has cats meowing...
meow...
meow...
meow...
meow...
meow...
meow...
meow...
meow...
meow...
Nah No need to hide. ETC
LOL HAI FAIVE!!
:sorcerer:
Yeah I agree, I don't think that woman are treated badly and I don't believe in feminist biartches.. I think they just have roid rage personally and it's an outlet...
The point to my previouse argument BOYS (not Anna for I love her so) LOL is that I don't like people trying to tell me whats right and wrong with MY body.. Female or male, but only especially males because they can never and will never experience what it's like to be a woman..
The woman who do that shit make me feel the most sick though... Us chicks are supposed to stick together and understand one another...
They are clearly robots...
<end rant v.2>
nothing ever too rude :laugh:
Image removed by Col of obvious reasons...
It's funny cos it's a cartoon...
Have u seen that anime porn where the chicks have special powers when the have sexings?
Their special powers is they grow wangs and fudge eachother LOL
It's hilarious
It's hilarious
Angel Blade???
he he he its funny but deffinately not work safe
me thinks col will remove it if you dont :laugh:
sorry Anna :fergus:
It's hilarious
Nearly EVERY Hentai I have seen has that as a theme :laugh: NOT quite. But most of them have vaginas that morph into monsters LOL
sorry Anna :fergus:
Yess thanks!
LUNCHINGS @ CAXTON. BBL!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
