little trick with oil filters i've found, grab a big long screwdriver, smack it through the filter and turn, hey presto it comes undone :laugh:
aahah ROUGH...
3/8 claw + 2inch 3/8 extension on a 3/8 rachet.. and if that dnt work.. rubber gloves..
aahah ROUGH...
yeah the screwdriver trick is nearly impossible on the 26, however i managed to get it :laugh:
i ended up breaking 2 oil filter removal tools, hence why the screwdriver came out :P
damn backyard bogan.. see im not dodgy like that lol..
hey shane do u rotate ur filter and put ur finger in the thread and pull it out like that past the dipstick and harness?
does anyone use a biger A/M P/S cooler..? for track or something..?
not needed unless its hardcore track car, i.e runs in improved production etc
sydneykid doesnt use on on his own car, but does on the race cars
I feel like shit as well. Do you have that random bug going around? f**king thing. It makes you a little bit sick for ages and won't go away. I'd rather be heaps sick for a day or two and then better again. Meh :P
And sif i'd blame shane. He's my lover-on-teh-side :laugh:
yeah it suck balls i've been feeling this way for a few weeks now.. on and off.....
ok, now again in english :laugh:
but thinkng for a dorifto car.. maybe. as u get the P/S fairly hot with all the opposite turning.. the car dnt like that lol :laugh:
As said, it’s not needed unless it’s a dedicated track car, however it’s being used more and more in drifted, as the racks obviously get a serious work out.
What car were you planning on doing this to?
doubt it man, ur not on the track for long enough stints to need one, maybe go onto the ns.com forums and ask there?
Can you drift though? Or are you just a power oversteer kid right now? Not picking shit, just I can see more value in mods to help you get better...
hi josh. not planning on doin this on any car. i wanna take lees car to the track sometime.. so im just wondering.. cause im a very cautious guys.. (shane and noel call it pussy) but i havent picked a shitbox cause i was cautious ahaha
how do u pull ur filter out of the car..? on the 26.. u have no room. i got my technique.. how do u do it..?
got it now nancy boy?
ahh see that wasnt so hard now was it lol (stoopid farkin kiwi's :laugh:)
i only did it once, and just like i told u, screwdriver through the filter (as it was tight as a mofo) and got it loose and did it with my hand. i dont see the issue with putting a screwdriver through the old filter, aslong as u dont hit the thread ur fine.
nah thats fair.. well i dnt ever try in the GTR as the attessa and weight doesnt make it possible.. also if i do hit something its too exy. i do take the S13s and S14s my mates have.. i work on em and i drive them lol.
but at the moment im very powah over. and im mastering my 90degree handbrakeys.. and clutch popping.. :laugh: still a wannabe lol
sounds rough though...
but wat if u cant get the filter off like in the GTR sometimes.. wat u gonna do then..?
Noel and Shane are right though, it is being a pussy. Don't own these cars, if you can't bare to see things brake.
Lee's car looks like a good, clean conversion. I'm not sure what is done do it, however you won't need to do any power steering work just for the odd day out there.
I would be looking at at bigger sumps, and oil coolers first to help keep the motor alive, then decent suspension, and mech diff then brakes if it doesn't already have skyline brakes
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
