wireless on laptop.. just unplug it from desktop still get net access..
ahaha my jade..? did u see her..? wat u think shane.. u knw u like asian/russians..
logan pub please.
i live next to the hyperdome.. 10min walk to cactus jacks.. which ill see u all tomorrow at..
put it this way, i'd be keepin 2 eyes on her if im around ;)
logan pub please.
I have wireless too hi5
I doubt u will see me for the next 6months, atleast
she was soo last year *does gay hand movements*
yeah thought as much ;)
ahaha... funny man...
put it this way, i'd be keepin 2 eyes on her if im around :P
i knew u would like.. ahah lee is just as bad...
wen u do meet her ull be suprised how much of a good girl she is..
also i bet ull drop ur nuts and cant get one word out. :)
also i bet ull drop ur nuts and cant get one word out. ;)
dude, dont tempt me, i have 'history' :P
press delete on first screen or somthing like that..?
anyone got a USB disc thats over 1gb i can borrow for a night?
thats the one, press delete at the start, takes u into a menu and look through until u find the boot sequence
mark u look like a faggy metro and u r a twink for logan sugar daddies
dude as if.. i dnt do my hair and dnt wear anything decent.. only do my hair when im out with her
dunno, but ur missus should be able to answer for me ;)
ok enough talkin bout her..
You gotta do better then that to wana make me drive 1.5 hours to farken Logan Bogan Home
i dnt live in the bogan part dude.. they still forsale..?
