Yeah I wee'd a lil bit in excitement just before.. :unsure:
I didn't eat dinner last night and I may not eat today to prepare myself for binging :P
bladder problems aye, should get that shit checked out :)
:) u didnt eat dinner last nite, u is crazy girl! goin for the store record of 8 bowls of chilli????
:O u didnt eat dinner last nite, u is crazy girl! goin for the store record of 8 bowls of chilli????
no no no... No eating comps for me's....
I like to watch :unsure:
Yeah I don't think spiratic urination is a problem though.... so I might just leave my lil bladder be :P
*shank*
what are u boys planning?
nooooooothing :unsure:
SO MY ADVICE ISN'T GOOD ENOUGH FOR YOU!?!?!?!?!?!?!
:P
:O
no!!!! just more opinions are always good!
plus i found a better way, got pics of my car, and am photochopping the paltes onto it :)
