pffffffffffffttt U wish u knew someone good looking enough to be up to my standards and could find out ;)
but alas....
:no:
Pfft, I'm the hot shit stop trying to wreck my ego!
So your saying you do like a good old dubble time fun :laugh:
by the sounds of her post above, i'd say she does love a bit of ye ol double time! :P
on another note, i need ur opinions ppls. which plate suits best?
by the sounds of her post above, i'd say she does love a bit of ye ol double time! :laugh:
I say second or third...
Although I might just be saying that cos I want you to look like a loser...
More so than usual :no:
But yeah seriously though, i'd probably got third
by the sounds of her post above, i'd say she does love a bit of ye ol double time! :)
Editing out pics because shane has a weeping vagina
second
Edited by Hell Fire
