was he weedy too.
Im cutting myself now that you think im weedy :P
oh he was weedier than shane!!!
maybe its true anna!
It was true. He talked about getting sex far too much :laugh:
attention seeker :)
We're all attention whores :no:
me backs!
*shank*
*bites boob
