*grumble*
cant sleep :)
dumb bitch at work is about to get pwned tomorrow. She is responsible for organising my accomodation, and recently has been putting me in shit places (crappy motels and such) even when my preffered places to stay are available. I have suspected her of deliberatley stuffing me around for months, I got her this arvo because the state manager said i was to get self contained 'apartment' style accomodation in rocky until i can find a rental flat (or similar) she first said "yes i tried everywhere was booked out" then 2 sentences later said "i was not told to book apartments"...ahhhhh!! finally i got her! HAHAHAH
yes i realise NONE of you care but victory shall be mine! :rofl:
whatas cracking shane
not much man, same old crap
found out some interesting info re my pay and compared it to a mates here...gathering info so i have some leverage with my pay rise on april 1 :bunny:
morning Ladies......
pay rise shane? does that mean we might actually see the 32 up and running???
hey fatty :D
yeah, shoulda been in feb but the fochers changed the system, and at this point in time they rnt going to back pay :bunny:
hey fatty :)
yeah, shoulda been in feb but the fochers changed the system, and at this point in time they rnt going to back pay :D
are we talking a significant increase here?
lol i still want to buy a GTR :bunny: but i wont but i will get me a crotch rocket lol!!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
