poo! its shane :kiss:
evening whorez. My last friday as a relief scientist, this time next week i will be on my way to rocky, banished to the wastelands of rural qld for 12 months :kiss:
hey isaac :glare:
whowhatnow? :glare:
we went over to boost earlier today and we went into their whoretown and started posting away, just like we do here and a certain mod over there got their nickers in a knot and 'banned us' and then came over here and has complained.
complained here? where?? to a mod?
yes to a mod, actually i think they complained to a fair few mods, caus an admin pm'd me not long ago about it :glare:
i wonder if they know the full story, caus we havnt been asked for our side, and i hope they (sau mods) havent just acted upon what the boost ppl have told them
Its f**king bullshit as an admin WHO IS A BOOST MEMEBER gave this account a warn. One sided, but this is the net, errm I have a life i can only asume they do not.
Edited by Mr Kofi Ahmed
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
