thats nice, that still doesn't make it a motorsport though :)
you have your opinion and i have mine, one thing we do agree on is that you need to get your car back on the road.
ps i think im more interested in circuit racing now but ill see how that goes
agreed, too bad i dont have 20k just lying around :)
im a big fan of circuit racing, but the costs involved in having a decent go are far too high
the people who built your car, seem to think otherwise.
you might be able to use your power if you start sliding, other then that you wont be able to use it..
somehow i dont see a big laggy turbo'd setup is going to work all that well 'drifting'. nor will it work that well circuit racing, theres only 1 left that it will suit :)
sooo true...
street racing.....
rofl, i've had heaps of people call shotgun now :)
yeah but you are a nice guy...soo.....
im not sure on the turbo to run though. dan says go the gt42r, but the guys at MTQ said the GT45R would spool quicker, but flow more >_<
i dont see how a smaller turbo will flow more...or a bigger turbo will spool quicker.....i suppsed the rear house size would make the different to a certain extent.
details?
rebuilt w/ turboport and race seals
microtech
gt35r w 1.06 housing
800cc primaries and 1600cc secondaries
frount mount
ext gate no screamer
its the one that made 365hp on 14psi, its now getting tuned to run 22psi and c21
microtech
frount mount
mmm tasty!
microtech
frount mount
B..B...B...b..b..bloody hell....secondaries?? do i need to research rotors a bit more.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
