heh i would come, but i just remembered i've got a mate coming over tonite to help me grind away at my block (well to grind it flat so the sump stud bolts will fit)
looks like i'll have to wait until tomorrow lunch with anna for my steak fix :)
i have a lisence, im just not allowed to drive :P other option, it taxis, i guess, but i dont like trains or bus, nasty
who does like the train or the bus....pfffft not me
and taxi's are nasty too...plus you may not get out alive, the way some of them drive :)
yep, he's gonna hold the block steady so it dont move and im gonna hack away with the die grinder :)...nah its just half a bolt hole for 5 holes caus the studs on the sump hit on the RB30 bottom end, and u need to also fit a nut onto the studs, so its just a little flatten of the side of the block, nothing major :P
Bryn your a big girl.......
is just a bus/train......
I actually dont mind public transport, i get to sleep or read and relax. takes a bit longger to get where your going but i ain't in no rush.
so just suck it up Bryn ya Skirt!!!!
BRYN IS A LITTLE CRY BABY BITCH!!!!
hmm sounds like your going to have fun,
when will it all be finished shane?
well once we get the sump bolting down fine (that should be tonite), then gotta take it to a welder to get some fittings welded onto the sump for the external pickup, (aswell as get the pickup modded) then its engine back in time, also ordered the injectors today finally lol. im hoping to get the engine back in next weekend if dan's got a free day. then the week after off to rob bliss for the exhaust, n then mercury for the tuning. 3 weeks til autosalon so if theres any dramas, i'll just tow it into brisbane for it :)
ill add to this and say that u also get to feast ur eyes on all the fine womenz (well i do atleast :P)...trains rnt that bad bryn, i travel on them 10 times a week...so im with lee, SUCK IT UP U BIG SOOK :)
Guest
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
