i have the hardest tme cooking for myself, last time i was by myself i somehow turned a packet hamburger into mince :P dunno how though and i made these awesome toaster sandwhiches that took me ages to prefer, and i burnt them to shit in the sandwhich press :no:
ha ha im not that bad lol i can cook,
im just too lazy to do it, and it ssuck when u are preparing a meal for 1 person bcoz u got a lot of trouble for 1 meal it sucks, or u cook enough for 5 ppl in one go then end up eating it all for like 3 days lol
Edited by 85URK
wow, cant believw you tube was started by teenages, who are now billonaires. i wish i had thought of something liek that
on the news they were like 27 year olds..... but yeah its crazyto think of somehting as simple as that and become a billionaire.
what are they gonna call it now??
GOOGLE TUBE!
yeah,, i normalyl jsut eat out for almost every meal,. parents leave more than enough cash,, or i cheat them by eating at home and poceting it all :P
i get sick of take out after like a week.
plus there isplenty of food left for me to cook, no need to waste it.
GOOGLE TUBE!
hmm weird,, thing i just heard said teens.. very wierd
Ma VC haz a prob hear is teh mssn thic whats wrong wif da car
Dazza says:
dam.....im out of bundy......can u plz go get me some
Bazza says:
nope, i drunk the last of ours a couple of nights ago
Dazza says:
all the bottelshops are closed too
Bazza says:
dont u have any goon in the house?
Dazza says:
ohh.....wait i got a few bottles of metho here
Dazza says:
$2 metho is a bit cheaper then $15 bundy
Bazza says:
so sayeth da black fellaz
Dazza says:
lol....maybe a can fiphon some fuel from my car
Bazza says:
ram raid ftw
Dazza says:
naaazzz da vc is in da shop bro
Bazza says:
ahh f**k, wat da problem now? f**kin carbs need adjustin?
Dazza says:
da mechanic sayed the injectors r seizd.....the methanol musta f**kd it
Dazza says:
na bro says da vc has da same engine as victa bray and he runs methanol
Bazza says:
daz rekon dat happenz when u run carbs an injectors...
Bazza says:
his mate had the injectors runnin fuel
Bazza says:
and had nos ported thru da carbs
Dazza says:
fuel is for weak ford......real men run methanol
Bazza says:
sounded sweet mate
Bazza says:
i run avgas on da cortina
Bazza says:
pffft.......its a ford it dont compare to da vc
Bazza says:
with da red panels on da back ppz at da airport fink its a 747 so its all good mate
Bazza says:
na cortina was made by shelby
Guest
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
