I just saw the latest ignition street dvd, and the Launceston hot scene was on it. I'm not sure if it's improved Tassie's image or not.
There was a nice R32 GTR with a HKS T51, anyone seen it round before?
Yep. The GTR used to belong to a guy down here. Willams Racing Developments.
T51R kai, 447kw! Not a bad bus at all!
Have watched this DVD and I agree with SAVMAN ............so funny! and the guy on the back of the ute on a bike at the end of the clip......hello ravo! :(
at least all the holdens and fords were screened out in the final cut! :D
that GTR has a tough motor....very nice.
but there was so many neons, crome, and sparkly paint I thought I was having a epileptic fit! through the clip! hahahahaha
.........fluffy pink boot.......hummmm not my cup of tea!......but it did match the pink sprayed engine!
well if the miners didn't put tassie on the map .....the DVD did! :P
It is now in lots of little bits after a little accident on the midlands and the police going over it a little closer :(
Not a bad car but was pretty rough when you went over it closely.
And im still not beliveing the power figures that it was supposed to have :D
My 2cents with ignition (dont take offence if our a ricer) it really isn't my scene, i can thinking of about 100,000,000 other things to spend money on before i was to make a little sh!t box front wheel drive car look all shiny, glittery and pretty :D
Cheers GMB
All the shiny, glittery and pretty cars were all those f**kers wanted to put in they're pansie-ass video.... they didn't want any real cars. Still, it makes us look a little weak tho. I still think it's funny as that hardly anyone went.... hahaha!
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
