if its ALWAYS at 2 then you've got an oil pressure problem.
go get your car checked with a manual pressure gauge at your mechanic.
if you do end up having a problem then its time for a rebuild.
Its not always at 2, when the car is cold, it's on 8 or so and moves towards 2. 2 is the idle value. When you put the foot down, it also rises. Sometimes close to have way. I just want to know why the oil pressure light is always on.
also, your oil level may be low. see if it needs topping up and check if your dip stick is properly in.
what kind of oil are you using?
I've checked the oil level and its fine and the dip stick is in properly. i'm not too sure about the oil i'm using. Could it be that the sensor is stuffed? Does that affect how the engine runs?
