  • Replies 67
I had just about beaten the 9.349 & now you tell me we can use TCS :)
That's bloody good, feel free to post up a non TCS time, it started as pretty much "whatever you need to do" challenge so any mods are fine. If you could get the launch perfect then TCS off would be faster I'd say but that is going to be pretty hard...
https://www.sau.com.au/forums/topic/119868-gt4/page/3/#findComment-2230842
Ok. FULLY modded inc NOS but with the TCS & ACS turned off = 0'09.371. I'll post a screen shot when I can find my camera. Might try it with the TCS on & see what I get :P
https://www.sau.com.au/forums/topic/119868-gt4/page/3/#findComment-2234644
9.337 is just about as fast as i can get it
With that sort of time I'd say your tuning is spot in, I had to break away from convention (well maybe it's not convention) in tuning my gearbox to get any faster. Hint hint, 5 gear changes in 9 seconds might not be the fastest way down the 1/4...
I had a freak run too...
https://www.sau.com.au/forums/topic/119868-gt4/page/3/#findComment-2234839
so are you just holding the nos and accelerating flat stick the whole time?
thats how ive been doing it
so how many gears are you using over the 400m?
also are you guys using any ballast weight?
https://www.sau.com.au/forums/topic/119868-gt4/page/3/#findComment-2234883
The Launch is the trick, need to get that right, then flat stick with Nos all the way, auto box but holding some gears a little longer using the gear shift button, 5 gears, using a taller final drive to get that, I was maxed out in 5th over the line.
Luke
Edited by munchdesign
https://www.sau.com.au/forums/topic/119868-gt4/page/3/#findComment-2234900
Luke
hmmm,
i was playing gt4 for about 4-5 hours last night, takes ages to get all the specs sorted.
i'll muck around with some of the specs and see how i go
https://www.sau.com.au/forums/topic/119868-gt4/page/3/#findComment-2234944
Never really found drag racing on GT4 that exciting.
I love taking the wagon around the dirt tracks. But my favourite is the Nurbergring. You have to set your car up spot on to get a decent time on that track.
If the car is too low, and suspension to hard, it is impossible to control over the bumps. If it is too soft, it just wallows and handles corners like a boat.
From memory, I managed a sub 10min lap in a standard RS4. I don't have a lot of time to play these days.
The PS3 is out in November (at this stage) and will cost NZ$1000.
https://www.sau.com.au/forums/topic/119868-gt4/page/3/#findComment-2236258
  • 4 weeks later...
  • 1 month later...
sussing some rim options... oh and has anyone got PB's for nurburgring yet, listen to munch qualifying tyres are the sh*t, GT4 has consumed so much of my life i have 384 cars at the moment that includes about every model nissan out the plus 24 different GTR's, 8 different stag's.... i like different colours and rims :thumbsup:
https://www.sau.com.au/forums/topic/119868-gt4/page/3/#findComment-2405300
All Silver ones, can' be bothered taking pics of the other colours just yet, been playing heaps of 'Tourist Trophy' from GT makers only motorbikes if no one has heard, pretty good not enough game play tho, and pretty easy. Tips for anyone taking pics on GT4 turn the brightness up heaps in the game makes them a bit better.
https://www.sau.com.au/forums/topic/119868-gt4/page/3/#findComment-2432574
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
