On first installation of a PFC, I use the Commander to;
1. check the water temp gauge calibration (where are 50/60/70/80 degrees on the gauge)
2. the boost gauge correlation (do they agree)
3. the alternator charging (battery voltage)
4. the throttle position sensor (am I getting 100% throttle when the pedal is to the metal)
5. the tacho correlation (do they agree)
6. the speedo correlation (do they agree)
7. the AFM cleanliness (is the voltage increase somewhat linear with rpm or does it jump all over the place)
8. check that the ignition timing is actually what it is running (using a timing light)
If I am tuning ignition timing, I run only knock display
Nice and large, very easy to see if changes in ignition timing (advance) cause knock
If I am tuning A/F ratios I run, injector duration and knock
Nice and large, very easy to see if changes in A/F ratios (leanness) causes knock and exactly how much injector timing I have left.
Generally I run AFM voltage, inlet air temp, injector duty and knock, as they are not covered by other gauges. Personally any more than 4 displays and I find it hard to read them while driving.
:( cheers :(
https://www.sau.com.au/forums/topic/119905-pfc/#findComment-2210124
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
