Hey guys im selling my laptop which i pretty much have no use for as i have purchased a new one.
I bought this laptop at my previous job as a salary sacrafice so i will personally need to write a receipt for it. Specs are
TAKEN FROM ANOTHER ADD CANT BE BOTHERED WRITTING
Intel Pentium M 1.4Ghz (similar to a Pentium 4 2.8Ghz! ) combining with Intel Pro 802.11b WiFi to form Centrino
1gb RAM
14.1 Inch XGA TFT Active Screen
Awesome Ati Radeon 9000 32MB Video Card (non-shared, dedicated video memory!)
60gb Hard Drive
DVD-CDRW Combo Drive
16 Bit Sound
PCMCIA Port, 2xUSB, S-Video Out, VGA Out, Infrared, Mic Input, Line/Headphone Output.
----> Built In 56K Modem <---
----> Built in 10/100/1000 Lan Card <----
----> WiFi Card (wireless 802.11b)<----
Battery Power Supply
Im chasing 850 so hit me up
https://www.sau.com.au/forums/topic/119977-dell-d600-latitude/
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
