Hey guys,
Kind of silly n00b question, but im stuck, where do i begin modding my car,
Essentially i want the car to slide well (drift), but do i start with power or handeling?
The car is completely stock bar the front strut bar and a pod, should i go for exhaust or coilovers?
Any suggestions?
Cheers
(sorry for the n00b question........)
https://www.sau.com.au/forums/topic/120054-4-door-r32-gts-t-mods/
Good to hear. I have a 4 door gtst 32.
If you want to drift a good choice is the suspention. Coilovers all around.
front mont cooler and then you can up your boost a bit.
17" wheels are better than the standard for drift, they also look far better.
you also will need to lock/remove your HICAS (rear steering) because drifting will become hard with any speed.
Mal
Edited by wal
(sorry for the misplacement of topic.... may bad)
Thanks for the info, i was leaning toward suspension, i was planning on teins and a hicas lock kit, looks like that will be my next mod!
I guess in the early learning stages power isnt important its more about technique and set up.
Thanks man.
Yeah mate if you're heading for drift a set of coilovers with 8kg front, 6kg rear spring rates. Pretty good balance for a daily driver.
Make sure to get a Hicas lock BAR. As some kits only add washers to the hicas mechanism.
If you can handle a bare boot> Strip it bare.. There's a good 20-30 kgs kg's in there.
After the suspension is sorted you should really look at a good mechanical LSD. But if the stocker is in reasonable nick you could probably get away with it for a few months(cause I know stock exhausts suck). If you're really cheap you can get it 'Shimmed up'. But they rarely last more than a year after that.
That was another question i was going to ask was spring rates, thanks Drift limo!
Shimming up the diff sounds like it will cost more in the long run, what are your guys opinions on KAAZ diffs???
The lock bar is def going in, hicas is annoying :D
Should i be installing sway bars with the coils and camber arms?
Cheers guys
I have a R32 sedan which I use to compete with in Perth. The basic mods I started off with was a catback exhaust, pod filter, hicas lock, front and rear strut braces and a set of coilovers. Which I found was more than enough to start drifting on. Since then I have added pineapples, GTR skyline rear swaybar (enables slightly more oversteer), a cheap spring type boost controller and a FMIC. If I had my time again I would spend the money on buying a decent FMIC kit, preferably one which has 'switchback' piping (comes in at the right and goes back the same way) because it will for one allow you to put in a decent size oil cooler in a convinent location and also avoid the heatsoak that the piping recieves through the crossover piping (which pretty much render's the FMIC pointless).
There is no need for 17" rims or tyres. I drift on stock GTS-T rims 205/55R16's front and rear with the rears sets set to 45 psi. However if you already have them good grip front tyres are definately a necessity. Before you go drifting on the track remove your rear seat and spare tyre and then you should be able to fit 4 rims with tyres in the area where the back seat was with ease.
Having more power always helps.. but its pretty pointless if you can't use it effectively due to lack of driver skill or suspension setup. Stock power with a catback exhaust and a pod is more than enough to start off with. Allows you to drift with your foot flat as well most of the time which makes it easier to drift on.
So in your position I would say lock the HICAS as a first priority then find some coilovers and then an exhaust. And this should be more than enough to get you started.
Oh yeah make sure your handbrake is adjusted properly as well.
Cheers,
Baz, this will sound wierd but ive sen you slide at wanneroo and your the reason i got a four door.
What youve just said makes mucha sense, looks like ill be doing that switchback idea too!
Thanks for the input guys, it will be put to good use!!!
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
