I thought you fixed that up... don't tell me you fried ANOTHER one?
Find out if the ones from a R34 will fit/work... I've got both sides lying around at the workshop.
HEY Hun... nah cause I've had the skyline off the road.. so i didnt bother fixing it...
ill ask if they will fit...
Thanks Hun
Yeah let me know, they're still in the the door assembly at the moment but it shouldn't be hard to get out.
I rang Tait and asked him.. and he said that he's quuite sure they wont fit, but ill ask around... thatnks heaps stan
I got my genuine used one from SSS.
If you buy genuine new, you will be paying HEAPS ($500?)
Don't get the aftermarket ones from JustJap - I got it and it f**ked itself after 2 weeks. They look very similar to genuine but because it's 1mm higher in one area it throws the whole thing out.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
